Google's Chief Java Architect admits that he copied Sun code into Android
Status
Not open for further replies.
One of Oracle's allegations of direct copying of code from the Java codebase into Android is a function that is in the Arrays class of Java and resurfaced in the Android TimSort class. The following image (click to enlarge) shows a line-by-line comparison of the two code segments -- it's fair to say they're simply identical.
"Q. BY MR. JACOBS: Do you have a recollection of accessing Sun code while you were working on TimSort?
A. I don't have a recollection, but I'm perfectly willing to believe that I did. You know, I think the similarity of the signature, the fact that, you know, the three arguments are in the same order and have the same name, you know, is a strong indication that it is likely that I did."
FOSS Patents: Google engineer admits to "strong indication that it is likely" that he copied Sun code into Android
Status
