Goophone I9 inconsistency in connecting
  • Start date Start date
A
Android Question
Guest
Recently bought a Goophone I9. From day one it has been inconsistent, it will allow phone calls both recieve and make, will text, and can connect to internet and email and then later wont. I will be in the same room so geography isnt an issue, i have tried a number of different sims and networks and the same results occur. Very frustrating as the phone only works 50% of the time. I thought it might be an aerial problem but it shows 91 DBa and 11 ASU. My other phone on the same network shows a similar level and connects every time. It usually has three bars the same as the other phone but whilst one works the other doesn't. Any suggestions? Is it a dud unit or is there something peculiar to this type of phone i am unaware of. Is there any firmware or software updates going around that might resolve the issue?
Cheers
