Help Got locked out of phone. Help!
wotpw
I got locked out of my phone after my schoolmate used the pattern lock too many times.
My data plan is disabled and so is my wifi. ( Can't use the google account login )
My security question also doesn't work for some reason.
How do I turn on my network if I'm locked out?
Do I need to do a hard reset? If so how do I do it?
I do not have USB debugging on.
did you fix your logout problem? if not, read this link
Unlock Android phone after too many pattern attempts | pinnapedia
