Root got update from metro pcs for 6.0 !
Yeah I just got an update notification as well (as of 5/14/2016).
I am not even running Stock, I have Katana ROM (V10j) installed.
Let's see what happens after dl & update :p
Edit) Since I have TWRP recovery installed. It can't install MM update file. I guess I will have to go back to stock or flash stock recovery.
just use twrp to delete the "android" folder on your SD before the first boot...
i've had new installs have repeat problems on other phones because of old data n obb files
I"ve gone back in forth several times with no problems using the flash tool and update file. I've rooted with both kingroot and the adb method. You can flash back and forth . Its all good.
I"ve gone back in forth several times with no problems using the flash tool and update file. I've rooted with both kingroot and the adb method. Its all good. You can flash back and forth . Its all good.
So, you can go back from Marshmallow back to Lollipop? That is something I haven't had the need to try.
