Is there a way to get total distance to destination on the Google GPS? It displays total time to destination and distance to next turn, but not total distance to destination.
The distinction is important whether you get it or not. The GPS receiver and your GPS app are entirely separate entities. You'll have better luck with discussions if you don't blow off others trying to inform you. Google has nothing to do with your GPS receiver. They have everything to do with Google Maps/Nav.OK. Whatever you say.
Google Nav does automatically. You're referring to Google Maps. If you want Maps to pan with your movements you need to hit the button at the top right (to the right of the Layers button):I played with Google Nav yesterday. I was surprised it was working a well a it did, however, it doesn't track, I had to manually move the screen, that wasn't convenient when traveling 70 mph.
