Mordechai6009
I have been having GPS troubles with my Galaxy s5 phone for nearly 3 months now and I still have not resolved the issue. This is what I have done so far to try to fix the problem:
1. AT&T refreshed my network twice
2. This started with my s4 and then I got an s5, and then I got another s5
3. I changed the SIM card
4. I called Samsung
5. I force stopped Google Maps and cleared the cache
6. Spent several hours on the phone with AT&T support and Enhanced support trying to trouble shoot the problem
7. Master reset
8. Downloaded and several GPS fix apps and tried to reset AGPS as well as recalibrate it
9. Go into safemode
10. Check the screws under the battery to make sure that they are not loose
And it is STILL NOT WORKING. I am at my wits end and I do not know what to do. PLEASE HELP. SOS.
4. I called Samsung
7. Master reset
9. Go into safemode
