D
Deleted User
Guest
Anyone know of a Widget that will toggle on/off the GPS on the HTC Incredible? No, I thinks but one that you use and know for a fact works. Thanks in advance for you input.
There's a widget that comes native with Sense that does it. You can also program Tasker to turn it on or off every time you launch a program that needs it. I've got a program that tracks my mileage for work. I set Tasker to toggle GPS on when I launch that program. It turns it off when I exit the program.
yea there is a 1x1 widget when you go to add a widget click on the settings one.
