Help GPSD Draining Problem
sondr
Hello,
I started having this problem with my galaxy sIII, Some application started to drain the battery so fast that it goes dead in a couple of hours while not being used , I looked at the battery usage and found an app called "GPSD" using 74% of the battery, I have no idea how to stop it I tried alot of things but for some reason it just wont stop, turned off radio and gps a couple of times , restart , deleted all the apps. is there any known solution for this ?
I would have posted a screenshot but I'm still a new user.
