same issue.  New Phone,, S7 edge - also bought an S7 plain
we bought two phones, a galaxy s7, and a galaxy s7 edge.
they BOTH have identicall settings, as far as I can determine (I even had them both at the samsung booth at BestBuy) -
the EDGE screen is turned off.
BUT, the EDGE continually has the ANDROID SYSTEM eating up power, see attached, both the CPU TOTAL and THE STAY AWAKE are always increasing clock time.
image references -
See PDF file
first two images, reflect the NON-EDGE phone, minimal CPU usage, even after about a day of being on, and has good battery life left.
next 2 images, reflect LOTS of CPU usage, and tells me to change to a lesser power-intensive location service, EVEN THOUGH it is set the same as the non-edge phone
NOTE, BOTH PHONES ARE AT GPS ONLY, for LOCATION, which makes the Edge's "change to power saving location" message confusing
of note, just after recharging, I was going through APPS, and found KNOX to be using about 2% of battery within 1 hour on EDGE, and ZERO percentage on non-edge
ADDENDUM, LOCATION IS AT GPS ONLY< for BOTH PHONES, which makes the Android-OS message for the EDGE very confusing (change to
I turned knox off, on edge, to test;  it DID slow down battery drain somewhat, but still decreasing at a percent or two every 15 minutes, even with nothing running
I've CLOSED ALL apps, I've deleted cache, etc.
PLEASE help me figure out what is doing this, so I can get extra battery life out of this.
These are brand new phones, and I am VERY FRUSTRATED at lack of info on web, the poor drain of battery on this EDGE phone.
PLEASE HELP.  WE had Galaxy S3's before, they were good, and these phones are good, BUT the drain on teh edge is unacceptable.
thanks
NOTE - just doing factory reset is NOT the best option.  Too manyh settings, passwords, etc, get lost;  even with samsung's SMART BRIDGE (or whatever) backup program
