GSM/WCDMA antenna boosters
kmf
Is anyone using an signal/antenna booster to get better phone reception at your home? If so, what product are you using? (No signal at home with the new T-Mobile HTC windows 8 phone and wifi calls no longer work.)
Luckily I don't need one, but if you can find one that supports T-Mo, get the Wilson. If no T-Mo HSPA support, get one for at&t, as at least you'll have a better Edge signal.
