Gt-p1000 not powering
hi team, i work as a technical support for our mobile customers at Vodafone Ghana and i would like to know;
What causes the GT-P1000 not to power up?
Possible solutions and
Preventive measures.
I would be grateful if you can assist.
Thank you.
Welcome to android forums. There can be tons of reasons for a phone/tablet not to power up. Probably the battery is dead. Plug your phone/tablet to an energy source and try to power it up then.. probably it would work. If not try to change its battery with a new one. Hope it helped you out.
Edit. Also try to reboot by holding Power button and volume switch pushed at the same time for several seconds.. More help HERE
Welcome aboard. I see that Flaviu has already responded to you with some good ideas on what possibly could be the caused of your problem. I hope you find a solution. Good luck.
Thanks for joining the forum.
