aio developers
This is the minimal way of fixing TWRP Common issues in mtk65xx to Mtk 67xx
Fixing Common issues in porting twrp
1.dont port TWRP from a phone with android higher version
2. Check default.prop But IF CWM created with Mtk droid tools you can use TWRP porter to replace it and it fix
3.dont port with device with diffrent GPu POWER vr to power vr ,mali to mali And MAKESURE THE GPu matches properly e.g PowerVR SGX 544 to PowerVR SGX 544
4.when porting twrp replace recovery.fstab and twrp.fsatb to mount properly but if using the TWRP porter i give It replaces it for You
5.if you have cwm recovery you can port to twrp
6.for mtk67xx dont use autoporter just download recovery with the sane or lower android version to work well
7.use phliz or CWM if it doesnt work thank me later
8.Make sure The kernel Matches PROPERLy dont Port 3.4.5 kernel TWRP to kernel 3.18 . LET ME explain
ALL phones have diffrent stock kernel e.g Mine in the Picture is 3.4.5 if you try Porting to 3.18 you can get issues Because The TWRP can get kernel Problems
9.Make sure the scren size matches e.g 540x960 to 540x960 1280x720 to 1280x720
10.For USB issues
init.mt65xx.usb.rc e.g init.mt6582.usb.rc init.mt6582.usb.rc
for mtk67xx
init.mt67xx.usb.rc
Questions?
CTR(Carliv touch recovery ) Touch is working well But not TWRP
Means Your default.prop have errors in TWRP
Check all your init.rc files because most times it Can be configured Wrongly also Check The .so LiBS in twrp and try Porting from the CTR(carliv touvh recovery) to TWRP
2.Sepolicy error after Porting TWRP
Replace the sepolicy file from stock Recovery to custom
3.Cant charge for my mtk67xx after replacing init.charging files
Replace the Charger file
4.Jpeg not working well in NEW TWRP BUt old
libjpeg.so
5.Not seeing My phone storage In recovery when plugged to my PC
Check Your MTK wether IS enabled and if it is try disabling and enabling it BACK
6.Rom Working IN cwm But not TWRP
Expirenced that issue with coolpad 7295 TWRP ,NOT all roms will install In twrp e.g The rom is deoxed and all those stuff Another Rom worked But not the 4.4.2 i saw on pan.biadu but ,What i did JUst use the CWM to Install then BACK the Rom Up with TWRP then to flash twrp Back you CAN use flashify
flashify.org to download
[It need root acess]
To flash root
http://www.supersu.com/download
6.Not Mounting Roms
Try Formating /system PARtiton as EXt4 or check the Rom Mounting
7.Cant understand Languange?
but everything is working
You can edit IN UI.xml
8.NEED to Customize picture
Check Res folder in TWRP
9.GETTING ERROR 7...In TWRP in my mtk65xx-mtk67xx
1.Your system PARtiton is way too small of space to install the rom
if Ported Rom try Debloating the Rom and deodexing IT
2. Try Formating your system Partiton with EXT4 BUT NOTE make sure you Know the roM mounting Points either EXt4 or ext3 via updater scripts
And ALSO backup Properly with both TWRP and PC
MTK 65xx
mtk droid TOOLS
MTK67xx
https://www.chinaphonearena.com/forum/showthread.php?tid=11542
10.Read and write permission fix
chmod 775
e.g You want An app to give a specific previlledge to a folder in /system/ partiton You can give it chmod 775 to acess it easier
OR use root explorer apk
https://rootexplorer.co/
And grant it your desired permission
Phone Tested
1.Coolpad 7295
2.LEnovo s850
3.Spice mi 515
Paypal: Paypal.me/speedevs
Signature:always on amphetamines turbo power
10.For USB issues
for mtk67xx
init.mt67xx.usb.rc
Questions?
libjpeg.so
To flash root
6.Not Mounting Roms
but everything is workingYou can edit IN UI.xml
MTK 65xx
mtk droid TOOLS
MTK67xx
chmod 775
Phone Tested
1.Coolpad 7295
2.LEnovo s850
3.Spice mi 515
