ROMs [Guide] Having a Phone heating Problem? Tutorial How to fix the Issue!
  • Start date Start date
D
Deleted User
Guest
Heres how to fix a cpu overheating problem by 50% more cooler then without this fix
*First youll need a mini screw driver made for phones
* youll need a Phone pryer or something flat and safe to use to lift the casing from its housing
* a Small 2x1 thermal pad or specific to your tasting or thermal paste, for now well dtick with the thermal pad
1. First you need to turn the phone off completely and remove your sd and sim from the phone.
2. Remove all the screws and lift off the back housing of the phone (Do it carefully some phones has wires and important connectors on the sides and top sides)
3. Once the back is off disconnect the connecters to the camera etc from the mother board this is need because youll be required to carefully remove the board from its housing.
4. Remove the mother board and flip the board over youll see some big chips we recommend you to judt put a thermal pad on the main cpu but other chips you can but depends on the room youll have when you place the board back in the housing.
5. Cut and measure the size of the thermal pad you need for a specific chip you are going to place it on and place it on the housing or on top of the chip itself
6. Once thats done, place the motherboard back into the phones housing unit and make sure while you do it the thermal pads dont fall off or get moved all to a different place
7 now reconnect all the connections back and securely and seal back the back housing of the phone and screw back the phone back in place and put your sd and sim and your battery.
8. Now turn your phone on and test to make sure your reconnections were connected properly you can tell if a connector wasnt plugged in correctly when something you want your phobe to do, does do what its told or nothing lights up
Youll notice after you done this your phone rarely get hot because thebthetmal pad cools the cpu by 50% more.
