Sepero
Linux Guru
Merry Christmas, I recently got this tablet. This advice is only for NS-14T002 (as far as I know). How to get Root access.
After finishing here, see my Guide on installing ClockWorkMod on Insignia Flex 8 NS-14T002.
Rooting
Wait a few seconds and your tablet should be rooted. The tablet already comes with a generic version of busybox preloaded, so you may not need to install busybox from the play store. Congrats.
Device partition information:
PS.
This tablet is also mistaken for model NS-14TOO2 (Someone in marketing put "OO" on the box instead of "00" zero zero). You will find NS-14T002 under the model in the device settings.
Rooting
- Make sure USB debugging is enabled on the device. For instructions, see my previous thread on adb insignia flex 8.
- Download Cydia Impactor for your OS.
- Reconnect the tablet via USB to your computer.
- Start the program as Administrator (run as root/sudo on Linux)
- On Windows, you will need to have the USB drivers for the device installed. You can also try the inbuilt Driver Scan function in Cydia Impactor to automatically construct and install a driver for your device. From the menu choose: USB > Driver Scan
- Making sure that # drop SuperSU su to /system/xbin/su is selected in the dropdown menu, and click the Start button.
Code:
mtdblock0 misc
mtdblock1 kernel
mtdblock2 boot
mtdblock3 recovery
mtdblock4 backup
mtdblock5 /cache
mtdblock6 /data
mtdblock7 kpanic
mtdblock8 /system
mtdblock9 /sdcard
