H96 max Ethernet problem
jhnelo
Bought a new h96 max android box but when plugging ethernet cable in to it, it doesn't recognise. I have tried setting up a static ip which it then says connected but if I check my connected devices on my virgin media hub it does not show and I have no Internet. The ethernet connected to my ps4 works fine so I swapped them to make sure they are both working which they are. Should the h96 box show a green light when a ethernet is plugged in?
Check with the manufacturer support, maybe you need to install a driver or configuration app? Does the manual or carton have a QR code on it, which you scan and might download their driver app?
Check with the manufacturer support, maybe you need to install a driver or configuration app? Does the manual or carton have a QR code on it, which might download their driver app?
No nothing like that. Been trying to look for a email for manufacturer support but nothing in the booklet. I thought these boxes were quite popular so thought I'd of fou d something while searching the Internet.
