Handbrake and Samsung S3 setting?
When I first converted video files in Handbrake using the Android Preset, the files would not play on my MX Player in my S III. I found a Forum recommendation saying to change the Framerate (FPS) setting in in the Video tab to "Same as source" and that solved the problem. I then saved those settings as a User Preset by selecting the Add button in the lower right corner of Handbrake. The files are saved as Mp4 files which is a good format for the S III. Hope that works for you.
