Handcent Locksreen Pop-Up...Not workin...
difabio42
I have a droid 2 and run handcent and it say click for messages to pop up in locksreen so I clicked it...the mesasges dont pop up in my locksreen.
Any ideas why it doesnt?
try this:
settings> notification settings > enable popup then > popup settings: check the box that says screen on for popup.
Edit: And per your post, you already have it enabled to pop up in lock-screen correct? I believe you need all three checked.
Hope this helps.
