Handcent to HomeScreen issues
ALNITLONG
Hey everyone. I have the motorola droid. I got the handcent app because I really like all the customization options within it. However, lately I have been having this annoying problem. Sometimes when I have just sent a message, when I press the home button to return to the homescreen, it goes home but all my apps have vanished. I can go through my menu and replace them all to where they were, or I can reboot the phone and that usually corrects it. It is still annoying and is really putting me off the app. Has anyone else had this problem? Do you know if there is a specific cause or how I can correct it? Thanks for any help in advance people.
No such problems here.
Are you sure this is caused by Handcent? I would think this is caused by your Launcher.
I use Handcent every day and I have not had such issue.
I doubt Handcent is causing problems here. Maybe you should check how much free memory is available in your phone, if its level is low, that could be a problem.
