I just installed Handscent on my slide and I have a question.
When I go to create a new sms, I start typing the name and can select who I want to send it to. Once I do that it shows their number in the to field as opposed to their name, until I send the message. Is there any way to set it so when I select a name it shows in the to field while I am writing my message. I use my phone for work and personal, so when it populates with the number, I cant make sure that I am sending to the right person. example:
if I have 4 andy's programmed in my phone and I wan to send a sms to andy 1, I want to double check before I actually send. I dont know everyone's number so if I happen to select andy 2, I would not know because I dont know andy 1's number by heart and I don't know andy 2's number either. See there name would be a lot easier to insure I am sending to the correct person.
Is there something i can set so it populates the to field with the name as opposed to the number so i can make sure before i send a message?
I appreciate your help.
