Apps Having problems on adding anroid plugin to my eclipse
xerxes
hi..im using linux arch... i downloaded eclipse galileo,android sdk and android plugin ..but when i try to add android plugin to eclipse as they told in this address ADT Plugin for Eclipse | Android Developers
it gives this fault:
Cannot complete the install because one or more required items could not be found.
Software being installed: Android Development Tools 0.9.7.v201005071157-36220 (com.android.ide.eclipse.adt.feature.group 0.9.7.v201005071157-36220)
Missing requirement: Android Development Tools 0.9.7.v201005071157-36220 (com.android.ide.eclipse.adt.feature.group 0.9.7.v201005071157-36220) requires 'org.eclipse.gef 0.0.0' but it could not be found..
can you help me about this ?
thank you .
I would guess the eclipse version you have doesn't have the prerequisites needed by android. Either you need to figure out a way to add the requirements to your eclipse, or you need to look to install a different flavor of eclipse that has all the prerequisites installed already.
well yea you are right beacuse i find a solution for org.eclipse.gef but now there is another one..
org.eclipse.wst.sse.core 0.0.0
it is hard to find these from eclipse'S webside anyway thank you for replying
What Eclipse did you install, I'm getting the same errors, I'm using the Eclipse Classic Galileo.
Code:
  Missing requirement: Android Development Tools 0.9.7.v201005071157-36220 (com.android.ide.eclipse.adt.feature.group 0.9.7.v201005071157-36220) requires 'org.eclipse.wst.sse.core 0.0.0' but it could not be found
I've followed the installation instructions precisely, set the PATH for the android tools directory, as well as the jdk, I have no clue what is wrong.
(Edit) The Answer To My Above Post :
+ Download the JEE Eclipse IDE
I am running linux. I was getting this error until:
1.) I put the directory of my SDK in the PATH. Then I restarted my shell. Then I restarted eclipse from that shell. That seemed to solve the problem.
2.) I also opened up the permissions in the eclipse install directory. Not sure if that made a difference, but I suspect the install of the plugin requires writing in the eclipse directory.
-hope that helps someone
