Having problems with Group Texting
OSU15
I can't receive texts from anyone within a group text that I've sent. My most recent problem occurred today where I made a group text between myself and two of my friends who have iPhones. I did not get a reply from them for two hours so I text them each individually and they tell me that they've been talking in the group chat the whole time however I haven't received any of their texts. Any solution to this or another third party messaging app that will do the trick? I've already checked "Message grouping" Under application settings for Go Sms
Handcent will let you do it.
Once you install, set it as your default SMS app.
Then go into Settings, Application Settings, scroll all the way to the bottom, and click "Thread group conversation."
Its not the smoothest, but it works.
Thank you for the suggestion but I'm not a huge fan of Handcent. Compared to Go SMS I just think it's a very sluggish messaging app. Could just be my opinion. Regardless, can anyone provide some advice to fix the problem with GO SMS or even Chomp as I would not be opposed to using Chomp SMS as well.
You might try in Go SMS Settings/Send Setting and check MMS Group Chat.
