headphone notification not appear
dreamb0yz
Guys... i want ask... usually we connect the ear/headphone always appear notification right? Today i try plugged in the earphone like usually but the notification not appear ... i already try reboot and turn off and on... but it's still same ... please help thanks...
Go to Menu > Settings > Accessory. Check mark Audio Applications.
Thanks... it's solved ... i don't know when i unmarked it...
I want ask too ... the default settings it's marked right ? And the earphone notification stay too? I think only appear "earphone connected" ... i mean the notif only appear 1 and then disappear XD...
And daviod ... can you tell the default settings of
Menu > Settings > Accesory ?
Which mark and which unmarked ...
Very very Thank you very much XD
I'm not sure if it's marked by default.
Have you recently installed a firmware update? Before the LFB update, the headphone symbol would show up in the notification bar automatically. After the update, it seems that they added this feature where you need to check the option.
In my Accessory sub-category, I only have Desk Home Screen Display and Audio Applications checked. I think that by default Audio Applications was not selected.
Audio Output is set as "Stereo".
yes i have update , but i don't know what's LFB update mean? ...then you checked the Audio Applications too? the Headphone Symbol appear at you Notification and stay too right? like a heatset small pic ... Sorry for ask many Question ... Thanks for the Fast Respond ...
LFB is just the latest version of the samsung firmware - if you go into settings > About Device the Build number should end with the digits LFB if you have the latest update.
Yes, then I checked the setting for Audio applications, and the symbol stays in the notification bar while I have the headphones connected.
At my build number didn't end with LFB but G1 ... how i got the latest update? Usually i connect to WiFi already got a new update ... :-( :-( i try check for software update at about device... but it's said "No Update Available" :'(:'(:'(
What the latest update add? My last update lookslike add Brightness at Notification bar and some special effect at Camera. . .
Really Thanks for you fast respond... i want ask last question... usually we play music player when earphoned connected there's no sound at speaker right? But when i sign in or sign out Yahoo Messanger i hear the sound at my earphoned and at my samsung galaxy s3 speaker too... the speaker behind the phone... why ? That's yahoo messanger features or something wrong with my s3 ? Thanks...
Don't worry, G1 is a newer release than FB. The biggest changes, such as the brightness control in notification pull down, and the extra camera features were made in the FB release, so I don't know what changes were made by the G1 firmware.
As to the yahoo speaker thing - I think that notifications still come from the external speaker even when headphones are plugged in, so I don't believe there is anything wrong with your phone in particular.
Umm, how about you daviod? LFB or G1 too?
btw , the Audio Application if unchecked the notification about "Headphone is connected" not appear right? and the Symbol too right ?
And about Yahoo , notifications it's mean sound? You Yahoo Messanger it's same too? The sound come from external speaker when earphone plugged / connected. . .
i want ask maybe this's out of this topic thread , you have encounter this problem ?
Swipe lock screen the rippling water effect can be laggy at times? any solution? or any thread about this problem?
and i want you recommended too , about the Cleaner you use? i don't know what application is good , i use FMR Memory Cleaner and Application Cleaner ... there's any software good for cleaner?
and Very Very Thank you Very Much xD
Can you please help me out. I have exactly the same problem with my new samsung c7 phien it doesn't have and option to turn it on. I'm using the earphones that came along with the phone. The notification was never shows when ever I plug in earphone.
hello friends i am using samsung A7 & i want ask.usually we connect the ear/headphone always appear notification right? Today i try plugged in the earphone like usually but the notification not appear .
