Headphone settings?
badduck
I keep seeing references that you are able to choose your headphone profile on the HOX but for the life of me I cant find the menu anywhere. I was hoping that by fiddling with this setting I might be able to boost the headphone volumes somewhat (I find them very low).
Can anyone point me in the right direction? I am on ATT fwiw...
Hi badduck,
Settings > Sound > Sound enhancer and then select from the drop down list. Choices are currently Beats urBeats, Beats Solo or Other.
Thats why I am confused, mine just has 2 radio buttons there, for enable/disable beats audio. No other drop down or menu settings.
had JB update and STILL the settings, sound enhancement method only gives the option to enable or disable the Beats profile....all the preset equalizer options are missing. Dissapointing!
