Headphone volume increase
I am new to this forum. This is my first post. I have a huawei ascend. I listened to my headphones at the loudest volume and I can barely hear them. Anyone have a solution to this. An app for it or anything internally. I appreciate all help thank you.
Ryan
Okay so I have the same problem. I downloaded volume unlocker but it didn't make the volume louder at all.
thanks for all the help. Sense the sarcasim. Didnt think it was a tough question. Ni one even responded in a helpful way. U all are great. Woo Hoo.
Well, the music app 'PowerAmp' actually has some great settings inside the app to boost your music volume. It has a 'Preamp' setting that essentially adjusts the gain on your music.
I think this is what you are looking for. Granted, this will only boost volume for music listening...but hey, that is all I listen to when I got my headphones in.
PS: I felt like the headphone max volume level on my HTC Incredible was low as well......this was my solution.
@stupifer thanks man that did the trick works perfect with my huawei ascend media volume was just too low now i get the extra volume level with the eq
Keep it low! Tinnitus and loss of hearing is no laughing matter, voice from experience!!
Got Tinnitus a couple years ago 24/7. Prior to that it was infrequent, now it a horrible situation without end.
Aircraft/turbine mechanic for many years. Would go back and work fast food to make the high pitch noise stop.
Glad I could help! Trial on that thing only last a couple weeks though. IMO, it is worth the high pricetag for the app though. Best music app on the market.
