That's pretty common with smartphones, tenderheart. There is a lot going on inside of these things, and when we add to it by using the phone for a while, we have to get used to a bit of warmth felt through the case.
But if you're talking about extreme heat, burning your hand, or coming close to that, you may need to have the unit looked at and/or replaced. How hot is it getting?
