Hello solved wifi phone problem
ok I will try for the 3ed time to post :D if your phone cant connect via wifi check you hub type 192.168.0.1 in your web browser and check that wifi is turned on may sound daft but mine was turned off by itsself somehow.
hope it helps someone out :)
I was using a G1 with virgin media hub
I'm glad you solved your problem and are willing to share your solution. However, your tip will fall a small audience here in the welcome section of Android Forums.
I suggest you click into your G1 area and share your tip there. You never know how many people might benefit from your shared experience. Here is a link to the G1 area: T-Mobile G1 - Android Forums
