Apps Help a newb with creating a variable
igorski88
So here what im trying to do. Im trying to set a variable that i can bring up later in another Activity but in the same packege.
Code:
public class MainActivity extends Activity {
	private int Item_Selected = 0;
    /** Called when the activity is first created. */
    @Override
    public void onCreate(Bundle savedInstanceState) {
        setContentView(R.layout.main);
        GridView gridview = (GridView) findViewById(R.id.gridview);
        gridview.setAdapter(new ImageAdapter(this));
        /** Called when the a pic is selected. */
        gridview.setOnItemClickListener(new OnItemClickListener() {
            public void onItemClick(AdapterView<?> parent, View v, int position, long id) {
            	Item_Selected = position;
                Toast.makeText(MainActivity.this, "" + Item_Selected, Toast.LENGTH_SHORT).show();
        Intent myIntent = new Intent(MainActivity.this, TabsActivity.class);
    	MainActivity.this.startActivity(myIntent);
SO I created the Variable and even tested in in the toast to make sure it works. Now I need to call on that variables information in the following code
Code:
private int Item_Selected;
	public class SyllabusTabActivity extends ListActivity {
		@Override
		  if (Item_Selected == 0) {
			  String[] Belt_Array = getResources().getStringArray(R.array.TanBelt_Array);
			  setListAdapter(new ArrayAdapter<String>(this, R.layout.list_items, Belt_Array));
			}else {
				String[] Belt_Array = getResources().getStringArray(R.array.GrayBelt_Array);
This is not working for me. How do i call upon that information?
1st problem is:
Code:
which needs to be
Code:
public int Item_Selected = 0;
if you want to be able to access it from another class.
Then, in SyllabusTabActivity, get rid of
Code:
int Item_Selected;
and then replace
Code:
with
Code:
if (MainActivity.Item_Selected == 0) {
HTH :)
it needs to be static also
1)
Code:
public static int itemSelected = 0;
or he could leave it private and use a getter
2)
Code:
private static int itemSelected = 0;
public static int getItemSelected()
    return itemSelected;
then to access it from other classes:
Code:
//solution 1
int myLocalVariable = MainActivity.itemSelected;
//solution 2
int myLocalVariable = MainActivity.getItemSelected();
//do some work
if (myLocalVariable == 1)
    Log.d("MyAppTag", "hi");
But the "best practice" way to send data would be in the intent
Code:
myIntent.putExtra("current_item_selected", itemSelected);
then inside onCreate() in SyllabusTabActivity
Code:
//get the intent passed to the activity when it was created
Intent myReceivedIntent = getIntent();
// get the int value out of the intent.
// -1 is the value we use if the int isnt found inside the intent
int itemSelected = myReceivedIntet.getIntExtra ( "current_item_selected", -1);
if (itemSelected  == 0)
    //do some stuff
