I install the BH_MAN_WarHeads。and I want to backup my rom,so I install the soft of RomManager.apk 。I open RomManager.apk and select [backup my rom]....
So Behold 2 is reboot. But bad news,it can boot anymore. it stop at
"Samsumg Behold 2"sign. I take off battery and put it again. but it does not working...
and it can not go into recovery.but the good thing is I can get my phone to download mode.
So I flash R11\R12\OEM....BUT nothing change,still stop at "Samsumg Behold 2"sign
So , What shout I do ?how do I Flash back to a build with Recovery / Kernel.
PS:I am a newbird.can you say it detailed and give me the important files
note my flash
Download Start...
<0> Create File...
<1> StartThread Detected : 1
<2> StartThread Detected : 0
<3> StartThread Detected : 0
<4> StartThread Detected : 0
<5> StartThread Detected : 0
<6> StartThread Detected : 0
<7> StartThread Detected : 0
<8> StartThread Detected : 0
<1> setup connection...
<1> odin mode.. check plcatform verification.
<1> START!!!
<1> check download environment.
<1> amss download..
<1> 1/3 Finished.
<1> kernel download..
<1> 2/3 Finished.
<1> system download..
<1> 3/3 Finished.
<1> reset pda..
<0> Started Timer
<1> Close serial port and wait until rebooting.
note my flash
Download Start...
<0> Create File...
<1> START!!!
<1> amss download..
<1> 1/3 Finished.
<1> 2/3 Finished.
<1> 3/3 Finished.
<1> reset pda..
<0> Started Timer
