Help Help!!!!!!!Bootloop....Cannot Go to recovery or mode After applying layers theme from play store
Zerulus
Hello,I have a Micromax Canvas MEGA 2 Q426. ..so I rooted it using kingroot. ..then I wanted my phone to look cooler so I found a theme manager from play store (layers theme manager) and installed it...then I downloaded Tronski Theme and applied it...then it said I had to reboot ...so I did....but when I did....The boot never seemed to finish.....It was a bootloop!...so I thought I'll just go to my recovery and fix things from there but when I pressed the key combinations it was a bootloop once again........
So can anyone help me?.....I need help or my mother's gonna kill me....please
Bro 1)u must have twrp installed...
2)just open file manager in twrp
3)go to / then system then vendor then overlays ...
4)delete every file in overlay folder
5) done
6)reboot phone and enjoy
5) done
I'd guess that by the fact the OP rooted with kingoroot, TWRP isn't available/installed. Do you have a link?
The thread is 9 months old and the OP is long gone, but TWRP may help someone else if you have a link to a working version.
hi bro... I rooted vias twrp.. I flashed twrp using PC and then installed super su... Any ways the link - https://androidfilehost.com/?fid=24459283995302412
But it may not work on some phones bcoz there are other versions for specific phones.. Googling may help to find appropriate version for appropriate phone. Thanks
