ArcticFox930
I need major help! Yesterday I had successfully rooted, installed TWRP Recovery, and flashed CyanogenMod 12 on my LG Tribute LS660. I didn't much like it, so I used TWRP to restore my stock backup. However, it was glitched out. There was no sound, GooglePlay wouldn't work, graphical issues. So for some reason I decided to try flashing something else. I ended up accidentally deleting my backup, and since hadn't had the Stock ROM. So I said f*** it, left it for the next day. Today I get up, I try searching EVERYWHERE for a STOCK lg tribute ls660 rom, couldn't find one. So I used somebody's supposedly "stock" deoxed rom or whatever. It worked, but being me I tried to still get the stock rom. I ended up using TWRP to flash another supposedly "stock" recovery image. Then I accidentally wiped the entire phone, including partitions and OS. I guess the stock recovery image I tried to flash didn't work, so now I have NO recovery and NO OS installed. When I try to turn on my phone, it just gets stuck at the "LG Life is Good" logo screen, absolutely nothing happens. When I try to enter Recovery, it just gets stuck in Factory Reset Processing, and when I try to enter download mode it gets stuck there too. I am absolutely lossed. If I was just able to get into recovery or download mode I could flash a rom using fastboot/adb or something, but I CAN'T. My phone has no OS, no Recovery, no nothing. It's just stuck. I'm not sure if this is what you call a "hard brick" or not, but I really need help. If you need more details I will be more than happy to provide. Is there ANY way I can fix this horrible mistake I've made, and install an OS or possibly even factory reset the phone, without having access to recovery? This is my only phone, my main phone, and I cannot lose it.
EDIT: I can access Download mode now, by holding Volume UP + Plugging in USB.
