help - buying used/second hand phone .. what to check?
InGearX
I'm lost my phone and I'm going to get a used android (I think Galaxy s3 again)
please help me compile a list of all the big and small and tiny things I should check before giving cold hard cash forever ..
list:
* microSD slot
* wifi
* making a call
* headphone jack
* clean ESN/MEID - if in USA
* call - gives you a decent indication of whether the earpiece speaker is blown or not and if the mic has gunk clogging it.
* Make sure it has an OEM Samsung battery.
* Make sure the screen doesn't have any hairline cracks.
* GPS works properly
* Make sure the screen doesn't have any hairline cracks. Also power the screen on to see if the LCD/Digitizer assembly was replaced with a cheap shit knock-off third party
* sensitivity of the touch
* Check all buttons to make sure they function correctly
* Check the water indicators if present to see if they're pink.
* Check the charging port to make sure the solder isn't broken and the phone isn't shorting out.
* Lastly, check the cameras to make sure they function, focus correctly, and produce a clear image.
thank you ..
