Help help camera not working
mobsper
dear reader,
my camera will not work.
every time I open the app it says "error cannot connect to camera.
ive did everything from power cycling and data reset. it does not work please help.
Does it not work on the stock rom or are you on another rom? Also did you
accidentally delete any important files that the camera needs to work with?
Mobsper, welcome to Android Forums. I wish it were under better circumstances for you, but hope we can help you get it worked out.
BTW, is your phone rooted?
what should be done if I accidentally deleted a file while deleting another app that might be using camera
