Help - com.android.settings disabled
tony_l
I am having issue with a custom android device loaded with an MDM that enforces the device into kiosk mode. The device will work and then eventually freeze at the android logo bootup screen. I was able to investigate that the issue was the com.android.settings was being disabled in the failure case. Does anyone know why or how this package com.android.settings can be disabled when configured in kiosk mode.
thanks
thanks
Is this a device from a correctional center?
No, just a custom android device doing a development on.
"kiosk mode" is only something I've read about with Android, and that is either to do with prison issue tablets, like the Jpays, or a device that is used for a dedicated purpose, like for a sales counter or a tour guide device.
I'm not a dev of course, but I think if want someone to help you debug your project, maybe you need to post your code, and/or what the exact hardware is you're working on?
