Root HELP! :( Cyanogen Mod 5.0.7
I have a ton of problems! I do not know why! Can't take videos it reboots. Anyone?
How long have you been using this ROM install (assuming you are on 5.0.7)?
If you have been on it a while, and now you have issues, it is probably because you have maybe installed an errant app that is causing problems.
If not, go back to a Nandroid previously taken, or backup your apps to Titanium Backup & wipe, flash again - there is a new CM ROM 5.0.7.1 out I know.
i just flashed it onto my device. it was 5.0.7.1 actually. i do not know why i would have so many problems. i wiped my phone and even the sd card.
*EDIT* Fixed it. Turns out the radio image from froyo was not compatible with cyanogenmod's ROM
