Apps Help debugging
maest
Hi,
I'm trying to write a simple app that plays a sound when a button is clicked and then stops playing it when the button is clicked again. I'll just copy-paste the code:
package tutorial.helloviews;
import android.app.Activity;
import android.media.MediaPlayer;
import android.os.Bundle;
import android.view.View;
import android.widget.Button;
public class HelloViews extends Activity {
boolean playing = false;
MediaPlayer mp = MediaPlayer.create(this, R.raw.play);
/** Called when the activity is first created. */
@Override
public void onCreate(Bundle savedInstanceState) {
setContentView(R.layout.main);
Button button = (Button) findViewById(R.id.play);
if(mp != null)
button.setOnClickListener(new View.OnClickListener() {
public void onClick(View v)
if(playing)
mp.start();
playing = true;
else
mp.stop();
playing = false;
There is a file called play.mp3 in /res/raw. When I try and run it I receive an error saying the app stopped unexpectedly. I've attached a screenshot from the debug window.
Is it something wrong with the code? Or is it the emulator's fault?
Does the play.mp3 file get uploaded on the emulator as well as part of the app?
Hi,
Please use the CODE tags when posting code so that indentation & layout are preserved. It makes it easier for people to read your code, and so they'll be more likely to help.
Also, you might want to consider pasting the text of the exception and traceback from the logs rather than a screenshot. (Also in CODE tags.)
Without looking at the code, I can be pretty sure it's not the emulator's fault.
Have you configured your activity in the Android Manifest XML file?
(If you're not sure, past your file into a reply, using CODE tags.)
Mark
Sorry about the CODE tag business. Was in a rush when I first posted this and didn't notice the tag.
Code:
    @Override
        if(mp != null)
                if(playing)
                    mp.start();
                    playing = true;
                else
                    mp.stop();
                    playing = false;
Code:
<?xml version="1.0" encoding="utf-8"?>
<LinearLayout xmlns:android="http://schemas.android.com/apk/res/android"
    android:layout_width="fill_parent"
    android:layout_height="fill_parent">
    <Button android:id="@+id/play"
    android:text="Play"
    android:layout_width="wrap_content"
    android:layout_height="wrap_content">
    </Button>
</LinearLayout>
Code:
<manifest xmlns:android="http://schemas.android.com/apk/res/android"
      package="tutorial.helloviews"
      android:versionCode="1"
      android:versionName="1.0">
    <application android:icon="@drawable/icon" android:label="@string/app_name">
        <activity android:name=".HelloViews"
            <intent-filter>
                <action android:name="android.intent.action.MAIN" />
                <category android:name="android.intent.category.LAUNCHER" />
            </intent-filter>
        </activity>
    </application>
</manifest>
and
Code:
Thread [<1> main] (Suspended (exception RuntimeException))
    ActivityThread.performLaunchActivity(ActivityThread$ActivityRecord, Intent) line: 2585
    ActivityThread.handleLaunchActivity(ActivityThread$ActivityRecord, Intent) line: 2679
    ActivityThread.access$2300(ActivityThread, ActivityThread$ActivityRecord, Intent) line: 125
    ActivityThread$H.handleMessage(Message) line: 2033
    ActivityThread$H(Handler).dispatchMessage(Message) line: 99
    Looper.loop() line: 123
    ActivityThread.main(String[]) line: 4627
    Method.invokeNative(Object, Object[], Class, Class[], Class, int, boolean) line: not available [native method]
    Method.invoke(Object, Object...) line: 521
    ZygoteInit$MethodAndArgsCaller.run() line: 868
    ZygoteInit.main(String[]) line: 626
    NativeStart.main(String[]) line: not available [native method]
For starters:
Code:
                if(playing)
should be
Code:
                if(!playing)
Also, set mp in the onCreate method:
Code:
I've never worked with a MediaPlayer before; so I can't say your parameters are correct. They don't make sense to me.
Cool, that worked, thanks. I just had to move the creation of mp to inside onCreate(). That was an oversight on my behalf.
