A
Android Question
Guest
Hi, I am trying to set up smart tv 220 GTV box
connection type DHCP
Static IP
Mac address....
IP address
netmask
dnd address
default gateway
These are the things I need help finding.I know the ip address what is netmask?
DND ADDRESS?
Default gateway ? and should I have mac address set as 00.0d.6b.3f.af
Seems that mac address keeps coming back and resetting and the check at end checked.Do I leave it as is
Thanks rose
Static IP
Mac address....
IP address
netmask
dnd address
default gateway
DND ADDRESS?
Thanks rose
