Here's my story:
I was kinda sick of the stock ROM, so I wanted to try out the Open Kang Projekt's ICS. And in order to do that I need to install Clockworkmod on my devise, and I did. But instead of installing the official CWM (which is version 4.0.0.4), I tried this: [Recovery] ClockworkMod - 5.5.0.4 - (Update: 03/18/12), I think it has the latest ICS kernel included or something (I'm not sure, that's what he said). And then I installed Kang's ICS ROM. Everything worked out just fine, except for the fact that it takes me every time about 5 minutes to boot, which is really a pain 'cause my tab crashes alot, and there are other bugs as well. So I decided to have a stable ROM instead of an unofficial ICS. But now I can't install any other ROM. I tried Slim ROM, Overcome ROM etc. but there's no luck, I'm always stuck at boot (Yes, I did wiped anything I could in CWM).
So now, what can I do?
I have wiped everything and flashed the official CWM 4.0.0.4 with Odin onto my tab, and I think that's the only thing I have on my tab now.
If I want to install Overcome's ROM now, what do I need. Do I need to install a bootloader? A kernel? What kind/version do I need. Shall I install the kernel first and then the ROM or the other way round?
And if I want to go back to stock, what do I have to do? Can I do that with Kies?
Really need some advice here. Hope you guys can help me.
BTW, my devise is Galaxy Tab 10.1 Wifi only.
