Help find
Yoursin
I'm rather new to this phone thing. I'm looking for the android setting for manage apps., where/how do I find it?
What are you trying to do?
To install apps tap the Play Store, it's usually on your home screen.
To remove apps go to your phones Settings -> Apps and tap the app you want to remove, the tap Uninstall. Apps that came with the phone can't be uninstalled.
Or something else?
Thank u, I did get it figured out. Maybe u could help with my tablet, its a notebook, an older one and it detects the SD card but won't mount it, any thoughts or suggestion would be greatly appreciated
