Hello, I have cheap chine Android box stop working stuck at the logo, I tried to reset the button from the back and same thing, I want to short the pins android tv box (unbrick) but don't have the right firmware and also the box don't come with SD card port also witch chip should I looking for, here is some pic if you guys can help me find the firmware or fix the issue this pic after I used the toothpick to press the hole between 2 USB. After 5-10 seconds, turn on the box
20mb image hosting
20mb image hosting
