hannahupton
Hello, I am hoping someone might be able to point me in the right direction with my S3... i should say from the outset that I understand next to none of the technical jargon but I will try to explain what happened.
Over the last few days I have noticed some quirks with apps freezing more than usual and then today my phone turned itself off a couple of times.
This evening it was sat charging and when I looked at it the boot screen was showing as if it had restarted but not got anywhere.
Battery in and out several times and soft reset and nothing is happening. Also just tried the hard reset buttons and nothing happens at all when I do home and power and volume up, though the download screen comes up when i do volume down.
I've resigned myself to losing my files that weren't backed up, pics and vids etc, but does anyone know how to actually get the reset to work so I can start from scratch with it?
Thanks
Hannah
Thanks
Hannah
