okay i am ******** i recently updated to haykuro's new spl because i wanted to try one of his newer roms and then i decided to try the rogers build... then that didnt work it force closed and said android process acore isnt responding and never let me even get to the home screen..
so now i re updated back to jf 1.51 and can get to the home screen but the gmail set up force closes... it says
rocess com.android.setupwizard has stopped unexpectedly..
any help at all thank you!!
EDITTTTT!!!! Okay its not just the setup its also the dialer it force closes while sending and recieving calls...
Please tell me i didn't completely Brick my phone...
any solutions??
rocess com.android.setupwizard has stopped unexpectedly..any help at all thank you!!
any solutions??
