Root HELP, I updated my phone while rooted but some other problems came
9000cody
So I kept having Gapp.process crash so i factory reset my phone and it was fine, Then It auto downloaded the update (C I believe) and never booted back up. I tried using the flash tool but it didnt detect my phone, But what i had discovered, In download mode, I was still in fastboot. The error reads Fastboot_init, Error: allocating memory for ssd buffer, yadayadayada. You know the rest. Anyway, How can I revive my phone because its the thing i use the most.
EDIT: Im rooted, No bootloader unlocked, Am I stuck in fastboot?
No, just keep holding the key combo until it says processing commands, then unlock, then boot into recovery via fastboot boot recoverynamehere.img
That wouldn't even help him, unless he had a backup. Use fastboot to flash laf back. Then you need to flash 10c again. Want root after? Google "lg new root method." Want to save userdata? Back it up via dd if=..of=.. command while using the send_command exploit. BEFORE you flash..
