gratt26
my wifes kryos mid 7015 was rebooting after following some custom rom install instructions... every thing seemed cool untill the reboot now it acts as if theres nothing on it all it shows is hardware info and says to connect to pc or reset.... after reseting 2x same results im trying to learn app dev. so i do have the sdk and eclipse...if any body can point me in the right dir.
