Help . Knowledge needed
Mysterka35
Hello, so I've been using Cuboid with Horizontech Falcon and I am quite confused. Now about coils.. i know if you have RBA or some other type atomizers you do change wire and cotton but this is not about that. i had V8 with Big baby beast before and I I know about those coils from before and um.. what about this one? What Kind of coils can I use for replacement? I read about falcon's limited variations but I am still green on this side. Is there specially only those coils that are written on package or does mesh coils may suit from any other 'heads' sorry for this question but I really want to know about this before my first and second coil meets their end
I don't know the Horizontech Falcon tank, only seen pictures, but I guess you have to use original Horizontech or compatible third-party ones. If it's compatible with any other manufacturers coils, I don't know.
I don't usually watch videos about vaping. Of course there are vaping forums you could enquire on. I only look occasionally, and are not a member of any, however I did go to Vape Expo Beijing last year.
FWIW I use a Smok Alien with Smok tank, I've had other mods but have found they just crap-out after a few months.
Yup. Smok is good one. . I don't know exactly how much time has passed but I am pretty happy with cuboid . Horizontech Falcon is good for flavour.
