Apps Help listView and onClickListener
ok so here is what i have so far
package​
list.view;
import​
android.app.ListActivity;​
import​
android.os.Bundle;​
import​
android.view.View;​
import​
android.widget.ArrayAdapter;
public​
class ListView extends ListActivity {
/** Called when the activity is first created. */​
@Override​
public void onCreate(Bundle savedInstanceState) {
setListAdapter(
new ArrayAdapter<String>(this,
android.R.layout.
simple_list_item_1, ANIONS));
public static final String[] ANIONS = new String[] {
"Acetate", "Bromine", "Carbonate", "Chlorate", "Chloride",
"Chlorite", "Chromate", "Cyanide", "Dychromate",
protected void onListItemClick(ListView l, View v, int position,long id)
if (position == 0){
setContentView(R.layout.
acetate);
if (position == 1){
bromine);
if (position == 2){
carbonate);
now im guessing that there is something wrong with this because whenever i click on an item in the list nothing happens. anyone know how to fix this or what im doing wrond? thanks.
It could just be me, could be that I dont know how to properly add the code, but im not having any luck. Will try a bit more. Thanks though.
