Root [HELP] Mac Address Unavailable, Wi-Fi Can't Turn On
qroenbamboo
I don't know why this happen to my LG D325, after reboot Wi-Fi won't turn on and when chek mac address it show unavailable. I try factory reset and still won't work. Some people say it can be bcmdhd.ko isu, and i chek, there is no file bcmdhd.ko in System>lib>modules. Is it possible because this file missing.
I try to search appropriate bcmdhd.ko for my phone but not found. Please if any one can provide this file or have trick toresolve this isue.
sorry for my bad english
Are your running stock or some custom ROM?
If it's a stock rom, you may always update your phone without loosing data with a LG Flash Tool and a proper KDZ file.
If it's a custom rom - dirty flash it from withing recovery and it'll replace missing files.
I am in stock rom and rooted. I can't update due rooted, get error 1xblablabla but i'll try to flashing, hope it can resolve this issue. Thanks for your response.
I returned to stock rom and not found system/lib/modules/bcmdhd.ko file,but I have mac address,perhaps this is another file.
Install LGMobile Support Tool and in options,select Upgrade Recovery if you get error,reconnect USB and press retry.
