gameelster
I need modem.zip for ZTE zmax pro (z981)
Im needing this modem zip too. my wifi and data have stopped working after installing twrp.I need modem.zip for ZTE zmax pro (z981)
Im needing this modem zip too. my wifi and data have stopped working after installing twrp.[/QUOTE
https://www.androidbrick.com/ultima...agon-xiaomi-mi5-imei-and-baseband-repair-fix/
This link but we need working zmax pro
To copy modem files from it
After installed TWRP , I was flash modem by zmax firmware by mistake ,,,Installation of TWRP recovery should have absolutely no effect on modems or WiFi. Flashing a zip while in TWRP can potentially do anything
Can someone post a link to rooting the zte zmax pro?
This is the most up to date information on that subject:
https://androidforums.com/threads/z...nt-on-this-device.1245962/page-6#post-7792885
For that thanks man.
But do you think its possible to install a Pie rom on it?
There's a lot of activity going on in the discord channel. If it's eventually possible to root it, then I'm sure someone will build a custom ROM, based on Android P.
I'm very confused by your answer. Someone already has root for it:
https://androidforums.com/threads/new-root-method-for-z981-zmax-pro.1284305/
Oh yeah. TBH I've lost track of what's going on with this device.
Does it work for you then?
I dont have the phone yet. I'm torn between buying this phone and the xiaomi mi max 3. I'm currently researching and being prepared in case I go for the zmax.
..Well I am currently busy working on oreo and so far it boots, but I need to fix an encryption issue and wifi, etc. Basically not ready for daily driver yetFor that thanks man.
do you have a backup of metropcs zmax pro data ???Well I am currently busy working on oreo and so far it boots, but I need to fix an encryption issue and wifi, etc. Basically not ready for daily driver yet
