tendoboy1984
Zenfone 4 Max (unlocked)
Pros: Huge 5000mAh battery, 32GB storage, 3GB RAM, fast camera, fluid UI, solid metal build, bright display, bottom speaker, fingerprint sensor
Cons: No NFC, Snapdragon 430, 720p 5.5” screen
Moto G5 Plus (unlocked)
Pros: Snapdragon 625, 32GB storage, plain stock Android, lightweight metal/plastic build, Moto actions, good camera, 1080p 5.2” screen, front speaker, 3000mAh battery, fingerprint sensor
Cons: No NFC, 2GB RAM, somewhat dim display, huge ugly camera
Moto G5S Plus (unlocked)
Pros: 5.5” 1080p display, bright screen, Snapdragon 625, 3GB RAM, 3000mAh battery, fingerprint sensor, pure stock Android, full metal build, Moto actions
Cons: Huge ugly camera, no NFC
ZTE Blade V8 Pro (unlocked)
Pros: 5.5” 1080p display, Snapdragon 625, 32GB storage, 3GB RAM, fingerprint sensor, NFC, USB-C, 3100mAh battery, solid metal/plastic build
Cons: Stuck on Android 6.0
Alcatel Idol 5S (unlocked)
Pros: 5.5” 1080p screen, Snapdragon 625, 32GB storage, 3GB RAM, dual front facing speakers, USB-C, fingerprint sensor, Android 7.1
Cons: Glass back (few cases available), 2700mAh battery, no NFC
LG Stylo 3 Plus (T-Mobile)
Pros: Removable battery, 32GB storage, built-in stylus, huge 5.7” 1080p display, NFC, 3080mAh battery, fingerprint sensor
Cons: Snapdragon 435, 2GB RAM, rear speaker, cheap-feeling plastic build
Galaxy J7 Prime (T-Mobile)
Pros: Bright screen, side speaker, removable battery, typical Galaxy UI and features, 3300mAh battery, solid plastic build
Cons: 16GB storage, 2GB RAM, 720p 5.5” display, no NFC, no fingerprint sensor
Nokia 6 (unlocked)
Pros: 5.5” 1080p display, NFC, 3GB RAM, pure stock Android, 3000mAh battery, solid metal build, fingerprint sensor
Cons: Snapdragon 430, HMD is a new and unproven company
Nokia 6 (unlocked)
