help me please m8n android tv box ??
franky1979
hello
i have M8N android tv box but after i flash my tv box is not working more
so i try again to flash my tv box but the tv box dont want to reboot more
now i see the noting more on my tv the Blue light flashing when I rebooted him
i try the next step
have also tested but not work fireware differed
sorry for my english
greating franky
DroidSticks Latest U-M8 Firmware Download
Latest U-M8 Firmware Download, this will work on – ENY EM8 The Square one not the round one.
If you have a M8, U-M8 TV box you can flash your device with our firmware. (fully rooted)
If you have a U-M8 TV box you can flash your device with our latest M8 firmware. (All fully rooted)
For an easy way to put your device into recovery mode download THIS APP and install it, this will allow you to reboot your device into recovery mode.
Get the latest software update for your U-M8
Latest U-M8 Firmware date of build 02/07/2015
EntertainmentBox Latest U-M8 Firmware How to Upgrade.
Latest U-M8 Firmware Download How to Upgrade.
  1. Click the link above and download the M8.zip file.
  2. unpack the 3 files onto a SD card.
  3. Do not unpack the ds-m8-ota——-.zip file
  4. Put the 3 files onto a SD card and put into the side of the M8
  5. Unplug the power from the UM-8 make sure it is off.
  6. At the bottom of the AV jack hole is the reset button.
  7. Using a tooth pick hold this button in. You know you have pressed it if you feel the click.
  8. Now plug in the power cord.
  9. While holding the reset button down, wait until you see the logo and you can then release the reset button.
  10. The recovery menu should now be shown and the device should update.
  11. If you see this error at the bottom of the screen when you try to update
DISCLAIMER
How to unbrick any Amlogic devices. Create an bootable micro SD card in minutes.
Posted in Apr 8, 2015 in News, Tutorials, 5 comments
The easiest way to solve this, without need of short circuit of the NAND pins, is to use Amlogic BootcardMaker to make a bootable micro SD card with your device stock firmware
A few days ago I tried to update firmware on my Vigica C90T Android TV Box, something went wrong and I bricked it somehow. It dind’t boot up anymore, I could enter the recovery menu from micro SD card with stock firmware on it, but it was impossible to flash the firmware, I got always the same errors, something like:
E:failed to mount /data (Invalid argument)
can’t mount ‘/data’ (Invalid argument)
E:Can’t mount /data/log/recovery_log.txt
The easiest way to solve this, without need of short circuit of the NAND pins, is to use Amlogic BootcardMaker to make a bootable micro SD card with your device stock firmware, in my case I needed Vigica C90T 20150211 FW.
So download Amlogic BootcardMaker, download your device stock firmware, launch the application with administrator rights, select your micro SD card as removable disk to be used, tick ‘To partition and Format’, then Click ‘Open’ and choose u-boot.bin from your device stock firmware package. Now press ‘Make’ button and when it’s done just copy all the firmware files to micro SD card (aml_autoscript, factory_update_param.aml, firmware.zip, recovery.img, u-boot.bin, unlock_autoscript).
Now insert the micro SD card in your Amlogic device and power on. You will be able to enter into recovery and the firmware will be flashed automatically. When the TV BOX reboots, remove the micro SD Card, this step is very important, wait 4-5 minutes and the update will completed. Next, follow the regular procedure and flash back to your stock firmware if this was from another Amlogic device, everything should be back to normal now.
Mentions:
– You can simply use this method also just to update your Amlogic device firmware.
– Download Amlogic S802 firmwares from he
please help me
franky
