Root Help me please.......
:(i changed my rom like 5 diffrent times and none of them worked now i cant even get on my tablet at all it sucks..... What can i do to fix this? Its a wm8650 3g 7 inches please help me with the correct rom needed for this tablet!!!!
Best I can say is to keep trying different numbers on Uberoid or to post there about it with a description of your tablet for them to compare to their list.
Hi, I would be glad to try to help you!
I have done many of these tablets and. I have enclosed my instructions below
and the link to the files from my website.
Follow these directions exactly:
Make sure your tablet is off.
Remove the SD Card.
Download the V9 Final ROM file to your PC from my site. Make sure you know
where to find it after it downloads:
I have uploaded the rom to my own website and it should
download very quick for you. Here is the link to my site
http://creativeconceptcomputers.com//downloads/public/WM8650.7z save it to
your desktop and get winrar to unpack the zip file at
http://rarlab.com/rar/wrar41b4.exe
Insert the SD Card into the media reader on your desktop PC.
The SD Card will now show up as a drive letter on your PC's File Manager,
just like C:\ except with a different letter assigned.
Every computer will be different. Let's just say that on your PC it is G:\.
Right click the drive letter of the SD Card (G:\). A pop-up menu appears.
Select "format" and format the card to Fat32.
Now, using a program like winzip or winrar, extract the ROM file that you
downloaded to your PC earlier to a new folder on your desktop
After it has extracted, it will have these folders:
firmwareinstall
Changer_files
and these 3 files on it:
changer.bat
wmt_scriptcmd
Universal_Uberoid_WM8650_v9.1.2.txt
Using your PC mouse, double click the "changer.bat" file. A pop up screen
appears.
Type in RT3070 and hit "enter" (this enables WiFi support)
Select the option number that corresponds to your tablet and press enter.
( I found option 27 to work on most wundermedia wm8650 ) if that dont work
run it again and choose option 2 (if that dont work,keep trying differnt
options until you get the right one)
if that one hangs on the option
you selected, you will just have to keep running the changer and selecting a
different option number until you get it right. Make sure that after it does
boot that the touchsreen does in fact work.
(Please, if you are trying multiple options, just remember to try options
only for the size tablet you have.
For instance, if you have a 7 inch tablet, try only options
1,2,7,8,9,11,12,13,16,20,21,23,25,26,27,28,29,30,31, and 32.
After you select your option number and hit enter, the changer.bat will ask
you if you want to install the ROM on your SD Card hit y (yes) and if you
want your SD Card formatted. Answer "NO" since you already formatted it
earlier, let the program finish running completly and it will tell you when
its done.
Now safely remove the SD Card from the PC media reader.
Insert the SD Card back into your tablet and turn it on.
it will show a progress bar on the botton, when it's done it will tell you
to remove the sd card , (don't remove card until it says to) when you do
the tablet will reboot
Select the wmtlauncher when it comes to options screen and set as the
default and thats all there is to it.
This should only take a few minutes to boot the first time. Make sure that
after the tablet is up and running , that you reformat the sd card in a
computer again before you put it back in your tablet for storage
Main features:
* Live Wallpaper Support! ("butterfly" live wallpaper included!)
* HoneyComb styled launcher, framework and icons
* Extreme WM8650 compatibility (60 models +!)
* Customizable ROM, make it even more LITE for example (see CHANGER 'x' for
more info)
* 100% Rooted
* Audio Boosted
* Memory cleaning boosted
* Memory read/write boosted
* Lite version, stripped away many apps
* Tries to support as many languages as possible
* Real Google Market (v3.1.3)
* Real working YouTube
:D Hi there and Merry Xmas!
I tried several of them, and some of them seem to work, but they do not activate Touch on my Pad.
Downloaded the old ROM, that works with Touch, but then Wifi doesn't work.
Says "unable to scan for networks" and shuts off again within a minute.
Even when i am sitting next to my Wireless Router.
Any ideas on how to get Touch activated or Wifi to work will be greatly appreciated!
I decided to open the pad and found the problem, Antenna wire was loose.
put it back in place, tested the pad and got WIFI again :D
Put the pad back together again, used a small screwdriver to pop the cover back in place and slipped, so now it is dead!
Anyone in sweden that needs parts? :D
Remove the SD Card.
firmwareinstall
Changer_files
changer.bat
wmt_scriptcmd
appears.
its done.
Main features:
more info)
* 100% Rooted
* Audio Boosted
I only get 14 options to select from, what have i done wrong?
